Want two computers exactly synced. Can't.
JoeMarfice
Post by JoeMarfice »
OK, I feel like I'm missing something really simple here.
I have a tower computer and a laptop. Both run Win10. SBF runs on the Tower, as Admin, every half-hour, and I want it to keep their D-drives identical. So, if I'm on EITHER computer and delete D:\foo.txt, within 30 minutes the other should also lose foo.txt. Instead, what happens is that foo shows up again on the first computer (it is back on both).
I don't want anything archived (I have a NAS for that, and do "dumb" copy-everything backups to there nightly). I just want to be able to change any file on either D: drive, and have that change reflected on the other computer. I realize this is probably something in my Decisions settings, but I can't figure out how to get it right.
Feeling kinda dumb... but this should be easy.
Re: Want two computers exactly synced. Can't.
Hi, you can't do this in the Free version, only in one of the commercial versions. Posts 1-3 of this topic have more background.
Note: that linked topic pre-dates the new 'SyncBackLite' version, which also supports Intelligent Synchronization, for minimum $ outlay; full version-comparison info here
This excerpt from the online version of the Help might assist also
https://www.2brightsparks.com/syncback/ ... ronize.htm
JoeMarfice
Thank you. And just to make me feel dumber... I already owned a SBPro license (v7), but forgot about it after a computer crash and rebuild.
So, I need to go home, reinstall SBPv7, turn off my SBFv8 profiles, and rebuild my profiles for SBP.
Remember that Intelligent Synchronization works using a state-history database ('what was where last time each side', and associated metadata), so on run-1 (no database to refer to yet - it's going to build one...), it will be restricted in what it can figure out from 'current state'. If you plan to do any testing, do a 'first run' first (a live run, not a Simulation) and be prepared to manually intervene (in the Differences window) if it proposes to re-create something you deleted (or the converse), and so on.
