Synchronisation of a NTFS volume using EFS encryption for certain folders
bejj
Post by bejj »
I have synced:
* D:\Documents\, where D is a NTFS volume using EFS encryption (Win7) for certain folders (e.g. D:\Documents\Private\)
to
* H:\Documents\, where H is a NTFS volume too
On the destination, I noticed that some files are encrypted, but not all, it seems quite random: some files in D:\Documents\Private\ are encrypted (they are displayed with green filename in the explorer), some are not.
How does SyncBack work with NTFS volumes using EFS encryption for certain folders?
bejj
Re: Synchronisation of a NTFS volume using EFS encryption for certain folders
Post by bejj »
Erratum: some files in (desintation) H:\Documents\Private\ are encrypted (they are displayed with green filename in the explorer), some are not.
I don't see an Edit option on the forum (maybe my reputation is too low?).
bejj
Post by bejj »
Any idea?
bejj
Post by bejj »
This seems to be the solution:
