Sync files between ShieldTV and PC
kaosikosmos
Post by kaosikosmos »
I have a 4TB usb drive connected to my nvidia shield tv.
I would like to sync files between this drive and my computer running windows 10.
ShieldTV is mapped as a network drive and i can access the files from the pc.
Left folder is on the pc and right folder is directed to the external drive on the shieldTV (the ShieldTV has adopted the 4TB external usb drive so its in theory a 4tb internal drive)
SyncBack reads all files and runs the program and all looks good. But the problem is that each time i run the simulation or task there are always collisions. All files thats suppose to be in sync shows as collisions. I have copied the folders with 414 files on each side so they are identical but still i get 414 collisions when running the task. I can then mirror left or right side but when running the task again the collisions are still there.
Someone have any idea whats going on?
