SBF freezes when I try to create a New Profile
MickeyNotD
Post by MickeyNotD »
In v 8.5.5, when I try to create a New Profile, once that window opens, that's it: the program freezes. I can't enter any text Profile Name or close that window. To close the program, I have to use Task manager.
I have seven profiles already. Is there a limit on how many profile I can have using SyncBackFree?
Any ideas?
Thanks!
Mickey
Re: SBF freezes when I try to create a New Profile
Hi, there's no limit to the number of profiles you can have in any version of SB (though if you have hundreds, it might be a little slow to load). As you've probably seen, there are no other recent reports on here of anything similar. I have a copy of SBF installed for testing purposes and can create a new profile OK despite having over 30 profiles already.
But I have no specific idea why you should get the lockup you describe, sorry. Have you tried a reboot? Has anything changed on your system (for example, a Windows Update) recently? You should also probably try a fresh install of SBF v8.5.5.0 (install over the top to preserve your settings and profiles).
MickeyNotD
Thanks cliffhanger. I downloaded and fresh-installed the program. I deleted the one Window's Update that was done, but to no avail....
However, I did find a hack: I copied a profile that I had made previously and then modified to fit the profile I wanted.
Maybe this could help if someone runs across the same problem.
