Is there any way, with SyncBackFree or any other version, to sync only the *.doc and the *.xls files?
Thanks for any help!
Only sync Microsoft Office files?
Re: Only sync Microsoft Office files?
Hi, you can use Filters, as per this topic, but in your case you probably should use Filters like this
*\*.doc
*\*.xls
and so on for any other Office file types you use (if any).
Do pay attention to the statements commencing 'Do not fail to enter....' & 'See here also....' in the old post, and read the linked stuff.
You can also jump to contextual Help on Filters by opening the Change Filter dialog (click Change Filters button) and then press F1
*\*.doc
*\*.xls
