In older versions of SBF, this used to appear in the text version on the log. With the new version, I am only seeing source copied.
With the old version, that difference told me that when a source was copied, it had changed as opposed to Not in destination, source copied which meant the file was new.
Am I missing a setting to have the Not in destination, source copied appear in the log? Is this no longer available? Is it only available in paid versions?
Any help would be appreciated.
Will
Re: Not in destination, source copied
In SyncBack V8.5.33.0 (Free, Lite, SE or Pro), when a new file is copied or existing file is updated, then the 'Copied, deleted, renamed, and changed' section of the log file simply shows 'Copied to Destination'.
Are older versions of SBF available?
Which version changed this behavior?
Will R
Will R
Sorry, we can't provide download links for outdated versions.
Thank you for your understanding.
