Comparison failure - can't read OneDrive synced data
Tiago Freire
Post by Tiago Freire »
Hi all,
I am trying SyncBackFree as a means to mirror from Google Drive to OneDrive (Sharepoint).
I am using Google Drive File Stream to sync my files to disk.
I am also using the OneDrive sync client to sync SHarepoint document libraries to disk.
Problem is, even though the files are on disk and available offline, the app can only see the Google Drive files, but not the Sharepoint synces files.
Can anyone help on that?
