I have the following folders:
*\*.dat
*\ABC_1\
*\ABC_1\PAT\
*\ABC_1\PATCH\
*\ABC_2\
*\ABC_2\PAT\
*\ABC_2\PATCH\
*\ABC_3\
*\ABC_3\PAT\
*\ABC_3\PATCH\
I was able to shorten to:
*\*.dat
*\ABC_1\
*\ABC_1\PAT*\
*\ABC_2\
*\ABC_2\PAT*\
*\ABC_3\
*\ABC_3\PAT*\
But if I tried to shorten to the following, it selects ALL folders under ABC_1, ABC_2 and ABC_3 and selects *.dat files in those wrong folders.
*\*.dat
*\ABC*\
*\ABC*\PAT*\
How can I do it so it selects *.dat files under (ABC_1\PAT and ABC_1\PATCH) and (ABC_2\PAT and ABC_2\PATCH) and (ABC_3\PAT and ABC_3\PATCH)
Thanks for your help,
Mario
What is the proper use of wildcard?
Re: What is the proper use of wildcard?
Please try with these inclusion filters ('to files/folders to copy' list) and see if it works:
*\ABC*\PAT*\*.dat
Click on OK button to close the settings page and confirm any questions you may be asked about excluding/including any matching files. However, please note that *\ filter will select all sub-folders on your source (matching or non-matching sub-folders). So, SyncBack may create empty folders on the destination device when the profile is run. But you can avoid this by configure the Decision-Files settings page as follows:
If you are backing-up files from a standard resource (local drive or network drive) then configure the option under:
Modify Profile > Expert > Decision-Files > Folders > "What to do if a directory exists on Source but not on Destination" (first section) to "Do Nothing"
OR if your Source is a non-standard resource (FTP) then configure the second section of the Decision-Files > Folders settings page to "Do Nothing"
*\ABC*\PAT*\*.dat
