Sync to/from OneDrive does not work anymore
BlackOnGrey
Post by BlackOnGrey »
I just updated to SBF 8.5.60. Since that, I can´t sync to/from my local OneDrive Folders (C:\Users\Name\OneDrive\...) anymore.
I always receive the error "Dive doesn´t exist" when starting the profile. In the the file selction dialog of the Profile Manager the folder can be found, browsed and selected.
I searched the forum and found the tip to deselect "Ignore NTFS Junction Points" but that doesn´t help.
With the Version 8.5.43 everything worked with no problems. After downgrading to 8.5.43 again it works like before.
So it seems to be a problem of the new version.
Any ideas? besides downgradin ;-)
Thanks in advance
Re: Sync to/from OneDrive does not work anymore
Can you please download and install the new SyncBackFree release V8.5.62.0 from here:
and see if it works?
BlackOnGrey
With the 8.5.62 it works.
Thank you!
