I can't restore Documents from an external drive
I have attempted to restore Documents saved in an external file by SyncBackFree but have not been able to do so. I have tried several times and the restore has been running for hours but after that I get the sign "failed" with hundreds of "errors". I don't know what I am doing wrong or why it should take so long. I am using an up to date version of Windows 10 as my operating system.
Re: I can't restore Documents from an external drive
I am not replying - I am wondering as to why I never received any answers to my question of October 31. 2018. Is it possible that I did something wrong?
Hi, SyncBackFree is free and doesn't come with technical support from 2BrightSparks:
https://help.2brightsparks.com/support/ ... 3000335580
The forum is primarily for users helping other users. I suspect nobody replied because you didn't provide the most important detail, e.g. what were the errors? You can often find a solution to common errors in the Knowledge Base:
https://help.2brightsparks.com/support/solutions
