In a profile I'm running the differences comes up in time - 1 hour difference.
Syncback says it is copying the file to the destination, but the destination time doesn't change to match the source time.
I can run this profile over and over, but the same files are shown.
Is there anyway to get past this ?
Source is on an old Win98SE (in use because of software) to a destination Win 7 computer run as adinistrator.
Thanks in advance for any ideas - I checked the forum and didn't see anything that would help.
Time Stamps not updated on files
Re: Time Stamps not updated on files
Can you please tick the option 'Ignore file date & time changes that are because of Daylight Savings Time (DST) changes' under:
Modify > Expert > Compare Options > Date & Time settings page
and rerun the profile to see if it helps?
