RUN: Does the folder being processed have to be deleted and recopied eash time?
jackdashack
Post by jackdashack »
I'm copying from a dedicated folder on C: It is mirrored on a USB Drive called USB Drive F:. Works pretty well. =D> But it seems as if each time I drag a fold into the C: dedicated folder, it will copy C: contents on a run but seems to delete the current contents of that folder on F: and all just to add a new different folder. Is that right? Can't if I drag a new folder/file in C:Dedicated Folder can't it just add that to F: Drive without deleted the contents of F: and copying all over again?
Clear as mud?
I will be grateful for any assistance. jack ":-Dx :?
Re: RUN: Does the folder being processed have to be deleted and recopied eash time?
Only an Intelligent Sync profile in SyncBackPro/SE/Lite versions supports file move/rename detection (with the options “Detect file renames on left/right"). If a file is moved to a new folder on Source then the Sync profile detects this and moves the same file to a new folder on destination (instead of deleting and recopying the file). For additional details, read this forum post:
viewtopic.php?t=12189
If you do not own a copy of SyncBackPro/SE/Lite versions and wish to test it's functions, you are welcome to try our fully functional SyncBack, which we offer a free 30-day evaluation.
jackdashack
You are the nice person that has helped me via support email the last few days. So nice of you to answer here. I will re-read this until I get what you are saying. Still fairly new to expert options. Thanks so much again. A helpful person you are! =D> :lol: =D>
You are welcome
