I have one server, Linux based, I use for some years like a backup cloud server. This work very well with client like Windows 7, Ubuntu and Android. But Not with Windows 10.
All programs I'ave used for connection work well without problem from years with this clients.
Now I would like connect another computer for online backup with SyncBackFree or freefilesync on windows 10 operative system and I'ave problem with FTP connection.
To do a test I also tried the ftp connection with filezilla and even here with win 10 I find the same problem.
The program I use like server FTP is vsftpd, but I'ave try also ProFTPD with the same problem.
Here some test:
server FTP on linux system ProFTPD (with vsftpd is very similar result)
----------------Test connection 1:
client SyncBackFree on Windows 10 32bit
Code: Select all
13/01/2019 03:48:33: SyncBackFree V8.5.97.0
13/01/2019 03:48:33: Windows 10 build 17134
13/01/2019 03:48:33: Resolving host name "82.**.**.**"
13/01/2019 03:48:33: Connecting to 82.**.**.** Port: 25
13/01/2019 03:48:33: Connected to 82.**.**.**.
13/01/2019 03:48:34: 220 ProFTPD 1.3.5a Server (MaxServerFtp) [192.168.1.8]
13/01/2019 03:48:34: USER odroid
13/01/2019 03:48:34: 331 Password required for odroid
13/01/2019 03:48:34: PASS (hidden)
13/01/2019 03:48:35: 230 User odroid logged in
13/01/2019 03:48:35: SYST
13/01/2019 03:48:35: 215 UNIX Type: L8
13/01/2019 03:48:35: Detected Server Type: UNIX
13/01/2019 03:48:35: RTT: 26.404 ms
13/01/2019 03:48:35: FEAT
13/01/2019 03:48:35: 211-Features:
13/01/2019 03:48:35: SITE MKDIR
13/01/2019 03:49:36: Timeout (60s).
13/01/2019 03:49:36: 3
13/01/2019 03:49:36: Client closed the connection. freefilesync on Windows 10 32bit
CURLE_OPERATION_TIMEDOUT: server response timeout
SITE MKDIR [curl_easy_perform]
---------------Test connection 3:
filezilla client on Windows 10 32bit
Code: Select all
Stato:  Connessione a 82.**.**.**:25...
Stato:  Connessione stabilita, in attesa del messaggio di benvenuto...
Stato:  Server non sicuro, non supporta FTP su TLS.
Comando:    USER odroid
Risposta:   331 Password required for odroid
Comando:    PASS **************
Risposta:   230 User odroid logged in
Comando:    SYST
Risposta:   215 UNIX Type: L8
Comando:    FEAT
Risposta:   211-Features:
Risposta:    SITE MKDIR
Errore: Timeout connessione dopo 20 secondi di inattività
Errore: Impossibile collegarsi al server
Stato:  In attesa di un nuovo tentativo...
Risposta:   220 ProFTPD 1.3.5a Server (MaxServerFtp) [192.168.1.8]
Comando:    AUTH TLS
Risposta:   500 AUTH not understood
Comando:    AUTH SSL
Comando:    FEAT
Errore: Tentativo di connessione interrotto dall'utente
