mickyj wrote: ↑Fri Jun 28, 2019 5:56 am
On Win10, on the "differences for profile" window when you select an item marked as "copy to destination" with a white background in the column Destination: you don't see the item name at all!
Having thought about this, I think I know what you're referring to. On the Differences window, if a file is only on one side (i.e. only in the source/left or destination/right, but not both) then when nothing is selected it shows the missing file in light grey text. If you select the entry then the filename is not shown (on the side it is missing from). This is to highlight to you that the file isn't there. It works exactly the same way in V8. If I've got it wrong, and that's not what you are referring to, please do submit a support ticket with a screenshot and details. Thanks!
Thanks for your previous reply.
Sorry for not posting an image right away!
I don't see the "light grey text" you wrote though, so I'm not sure we are talking about the same thing.
By the way there is another thing I would like to say:
start a profile, switch to another program while SBF is still scanning, when the step of scanning source+destination is over the Differences Screen pops up and the icon of SBF on the tray bar of Windows becomes blinking orange (meaning it wants your attention), but after a couple of seconds it goes back to when it was scanning (flashing green, like it's still scanning), so if someone misses the quick orange flashing would still think this preliminary scan is not over yet.
Also about "Prompt to retry if a file is locked or cannot be copied": when this warning pops up the whole profile is stopped, while it would be good if it continued in the background if possible, in case the user is away from the pc for a while.
Thank you for everything.
