New to the product. Is there a way to use date/time components in the file name so that the automated/scheduled backups can have the date/time within the folder or file name?
Thanks in Advanced...
Date STamping Folders/Files
Re: Date STamping Folders/Files
Yes, you can. The Pro & SE products support what they call "Advanced Environment Variables". This is not in the Free version. But you can use the standard (DOS) environment variables. What I do is to run Syncback from a batch file, that sets the environment variables with the current date or time, when it is run, and use that environment variable in my profiles. Here is an example:
RunSyncbackFree.bat Batch File:
ECHO OFF
set month=%date:~4,2%
if %month% EQU 01 set mname=January
if %month% EQU 02 set mname=February
... (lines cut, you get the idea)
if %month% EQU 12 set mname=December
ECHO ON
set year=%date:~10,4%
set month_year=%mname%_%year%
"C:\Program Files (x86)\SyncBackFree\SyncBackFree.exe"
Now in my profile, I set the destination directory name to something like:
D:\Backups\%year%\%month_year%\
And this give me directory a directory structure like:
2018\
January_2018
February_2018
December_2018
2019\
January_2019
February_2019
This, for example, puts all my January 2019 backups in the same directory, and gives me better organization.
I hope that this helps!
Regards,
Michael
ECHO OFF
ECHO ON
2018\
January_2018
February_2018
December_2018
2019\
January_2019
February_2019
Regards,
Michael
This is awesome. Thank you so much for your help and response.
