Looking for suggestions. FTP stopped connecting around the same time as the update with the new look. I have been using this for years. When I test FTP setting it starts to connect then says: 421 Failed to create data connection socket. SyncBack then freezes until I manually shut it down and restart the program. I installed a standard FTP client on same computer and it connects perfectly.
Any help would be appreciated.
FTP Issues
Re: FTP Issues
Please submit a support ticket by using the Contact Support in the link below and attach the support zip to the contact form.
https://help.2brightsparks.com/support/ ... 3000335603
If your Zip is over 30MB then contact us for alternate instructions advising the actual size.
