Backup operation without file
Hello, I'm a new user and I greet all the forum members. I've installed new version of Syncbackfree (9.0.7.10) and I have troubles with a new profile. Wheh I launch the backup operation that does not find new files the program opens window without files but asks to continue the backup operation,as if it had new files. Often a Windows Notification appears which says that the profile must be checked but all seems to be in order.
Re: Backup operation without file
Modify profile > Expert > Compare Options settings page
to skip the Differences Window when there are no files to display. Please read the help file > Compare Options settings page for more details about this option.
viewtopic.php?t=13287&p=50102#p50106
To switch off the notification:
Modify profile > Notify settings > un-tick the checkbox "Display a notification when a profile prompts"
You can also turn off this option for all profiles under:
Modify profile > Notify settings > tick the checkbox ‘Disable profile prompt notifications for ALL profiles or from the main burger menu > Global Settings > Easy > Disable profile prompt notifications for ALL profiles.
You can enable the option ‘Do not show the Differences screen if it is empty’ under:When I launch the backup operation that does not find new files the program opens window without files but asks to continue the backup operation as if it had new files
The details about Windows notification are discussed here:Often a Windows Notification appears which says that the profile must be checked but all seems to be in order
