Unable to create schedule when signing onto Windows using smartcard
jrenfree
Post by jrenfree »
I need to sign in to my computer using a smartcard, however when I try to create a profile schedule in SyncBackFree, it asks for a user password, which I don't have. If I leave it blank and hit OK, it gives an error indicating "Smartcard logon is required and was not used." If I enter my smartcard pin as the password, it still gives the same error.
Is there someway to create a schedule when the only way I can login to my computer is with a smartcard?
Re: Unable to create schedule when signing onto Windows using smartcard
Please refer to this forum post for more details about your issue:
viewtopic.php?t=12099
jrenfree
Post by jrenfree »
In case others have this same issue, I resolved it by manually creating a Window Task Scheduler profile to run the desired profile in SyncBack (this is essentially what SyncBack does when you create a schedule within the program). Using a PC on which I had admin rights, I created a schedule in SyncBack, then opened up Windows Task Scheduler to view the newly create profile. I then manually created an identical task on the problematic PC, and everything worked fine.
