Versioning...?
bigtpsharrks
Versioning...?
Post by bigtpsharrks »
I did not see versioning info in the settings/prefs. This page suggests there are such settings https://www.2brightsparks.com/syncback/ ... rsionskept
This forum had no search button until I logged in. I looked all around for it. If you are going to require logon for search, say so by linking the search button to the logon.
Re: Versioning...?
Versioning is only available in SyncBackSE and SyncBackPro (not supported in SyncBackFree). If you do not own a copy of SyncBackPro/SE and wish to test it's functions, you are welcome to try our fully functional SyncBack, which we offer a free 30-day evaluation.
bigtpsharrks
Re: Versioning...?
This is bad.
A free version should tempt the tester with PRO features. I looked through the settings several times, RTFM, looked through settings again... you failed to provide required information. And you have forum search challenges. Your resume has been moved to the bottom of the stack.
mike.c.carroll
Re: Versioning...?
Post by mike.c.carroll »
Hello bigtpsharrks,
Instead of blaming tech support for your failure to do more research; here is a detailed comparison of the different versions and their features.
There is a reason why there are paid vs. free versions. You can't get everything for free. I've used a lot of backup & synchronization programs in my 20+ years of being a Systems Administrator. I personally use SyncBack Pro and have for about 11 years now. It is one of the best in terms of features, flexibility, stability, & cost.
https://www.2brightsparks.com/syncback/compare.html
Cheers!
-Mike
bigtpsharrks
Re: Versioning...?
Let's be proactive here.
Suggestion: Pro features should remain visible (grayed out) in the product.
Suggestion: Documentation should clearly state what versions of the product apply.
Suggestion: The forum search should be grayed out with a link to logon.
I have not requested free tools.
I have not blamed anyone.
This thread is open for anyone who had similar issues looking for features and info which is not where it should be.
If you disagree, fine, but do not misstate the OP.
mike.c.carroll
Re: Versioning...?
Hello bigtpsharrks,
From the SyncBack Free manual:
"Versioning is only available in SyncBackSE and SyncBackPro. For a description of versioning see the section What Is Versioning below. Versioning cannot be used (on the destination) when compressing to a single Zip file, or when doing a backup to an email server."
I was able to find this pretty quickly in the manual as well as the comparison of features link. The option may not be grayed out in the application on the free version but I would think that if you were having issues with it you could've checked the user's guide. The above text that I copied is from the very 1st section in the freeware user's guide when searching on 'versioning'
I guess you may need to read a little more carefully . . . !
bigtpsharrks
Re: Versioning...?
Again. This page on versioning does not state what versions are compatible.
https://www.2brightsparks.com/syncback/ ... ioning.htm
I've been clear, yet you persist in this nonsense. Move along.
mike.c.carroll
Re: Versioning...?
Hello bigtpsharrks,
Yes I do persist; because I've been a Systems Administrator for 20+ years now. I do this because I like to solve puzzles problems & help people where I can. Yes, in the link you provided there is only one reference to SyncBack Pro but myself being curious; I loaded up SyncBack Free v9.08.12 Portable (no-install) & set up a test profile and looked through the options. After checking through all of the profile / application options in each of the tabs & double-checking; I could find no reference of versioning in any section; either in the 'simple' or 'expert' mode.
In the Pro version on the profile set up; there is an dedicated tab to configure the options for how many versions you want saved & where.
Thinking logically, & knowing there are different versions of Free, SE, and Pro; I would've deduced read through the section on versioning and/or the comparisons of features for the different versions. All of which I've linked to you. Sorry to sound rude; but I guess you're too dense to admit where you're wrong, not doing enough research, and/or expecting the Pro version & features for free.
2BrightSparks tech support linked you the versions where you could test it out and then decide to buy a license. Quite honestly, $ 55 for a application that has as many features & stability that SyncBackPro has is a small price to pay. I've even purchased 3 years of software assurance with my licenses because I see the value in their software & know that it takes resources, people & money to develop software & the tech support to assist other.
We're just trying to help you; you need to admit you're wrong & move on. I'm done trying to help you as you just don't get it . . . Hopefully someday you'll learn how to use Google too.
Cheers,
Mike
