Ignore Hidden and system files in backup
Twangster77
Post by Twangster77 »
Is there any setting that would ignore the system files and hidden files while doing a backup? This would avoid getting unnecessary error messages. :D
Re: Ignore Hidden and system files in backup
You can enable the options 'Do not copy hidden files' and 'Do not copy system files' under:
Modify profile > Expert > Compare Options > Attribute settings
save the settings and run the profile.
Twangerine77
Post by Twangerine77 »
Thanks...
I'm trying to backup my app data from my user account in Win 10 / 64. Is there any way to do that without getting so many errors from locked files and folders?
SyncBackFree does not support copying locked files. If you want to copy open/locked files, you can use SyncBackPro/SE versions. If you do not own a copy of SyncBackPro/SE and wish to test it's functions, you are welcome to try our fully functional SyncBack, which we offer a free 30-day evaluation.
