Hi, I need to make an unattended copy in an SD.
The SD is encrypted with bitlocker, and today this is my solution.
I wanted to share it in case someone is helpful.
1) Create your profile
2) Create your bitlocker unit
3) Create .bat file with this content:
___________________________________________________________________________________
@echo off
manage-bde -unlock d: -rp xxxxx-xxxxx-xxxx-xxxxx-xxxxx-xxxxx-xxxxxx-xxxxxxx
TIMEOUT /T 20 /NOBREAK
"C:\Program Files (x86)\2BrightSparks\SyncBackFree\SyncBackFree.exe" -m "YourProfileName"
manage-bde -lock d: -forcedismount
exit
____________________________________________________________________________________
The "d" is my unit, put the letter of your encrypted drive.
The xxxx.xxxx.xxxx ... is the encripton key which provides the recovery txt file.
The 20 is the time to pause, put the time you need.
When you have created the .bat you must create a shortcut to it and give Administrator permissions
(Right button properties, advanced options ...)
I hope it is useful to someone.
If you have a better idea, feel free to share it!
SyncBackFree + bitloker - my solution ...
