Bonjour
Chaque fois que je veux modifier quelque chose on me demande mon mot de passe Windows sur MON ordinateur
Peux on désactiver cette fonction inutile et embarrassant (boring) /
Merci
WHY BUY PRO IF YOU NOT PARLER FRANCAIS ?
Vous parlez Français ?? (Tiny country in Europe)
Re: Vous parlez Français ?? (Tiny country in Europe)
Are you prompted to enter the password when creating or editing a schedule task?
If yes, please note that the prompt is coming from Windows Task Scheduler, not SyncBack. Note we do not have a scheduler in SyncBack. We rely on Windows Task Scheduler(WTS) to trigger our program on the scheduled date/time to run the tasks. When you create a Schedule within a profile, we are only providing a drill-down into the Windows Task Scheduler interface through our program settings interface to facilitate SyncBack users in the creation and configuration of a Scheduled Task.
Therefore, when you create a schedule task in SyncBack, the Task scheduler of your Windows is requesting for the user’s Windows password. You need to enter the correct Windows login password to create/edit the schedule task.
