Log Files Being Email Four Times
otronics
Knowledgeable
Knowledgeable
Post by otronics »
Hello.
Using SyncBackFree V9.0.4.1 (32-bit)
I have various profiles that have been running for years.
One has all of a sudden started sending the log file email four times each day (at the same time). So I get four large emails at about 06:04 each morning.
Other profiles are emailing once as they always have.
Any ideas?
I note in the SMTP debug log it says:
Code: Select all
start to connect 23, 1, 0, 0x00000000
connect failed, error: 0x0000274d
start to connect 2, 1, 0, 0x00000000
connected
Re: Log Files Being Email Four Times
Try deleting and recreating that profile and see if it works. The possible reasons for receiving 0x0000274d error are explained in this article:
https://help.2brightsparks.com/support/ ... 3000335855
otronics
Knowledgeable
Knowledgeable
Post by otronics »
Recreating the profile seems to have fixed it. Bit of a pain having to start from scratch though. Thanks.
otronics
Knowledgeable
Knowledgeable
Post by otronics »
Spoke to soon - the issue remains.
I think I need to check with my email provider.
