Hello
In the Profiles list, the "Type" column indicates "Save" even if I initially chose "Mirroring".
How can I be sure of my settings? By opening the Profile where can I check that it is really a "Mirroring" ?
Thank you and have a good day.
Save, synchronize or mirrorer
Re: Save, synchronize or mirrorer
You can check the Type of a profile from:
Modify profile > Easy > Type settings page
