What are "collisions"? 7 Critical Errors!
markfleener
Knowledgeable
Knowledgeable
Post by markfleener »
The run to mirror two external USB drive (same kind) failed giving me a "critical error" message saying that 7 files couldn't be copied, deleted, or compressed. Then it took me to the following link showing 6 collisions. I don't know how to make sense of any of the info there or what to do...
file:///C:/Users/markf/AppData/Local/2BrightSparks/SyncBackFree/Logs/Backup%20Drive%20Mirroring_Log_Page1.html
Could it be that file names are too long? Or maybe it can't make the edits I made to the original drive for some reason? I remember changing the names of some folders, I think, maybe some files too.
markfleener
Knowledgeable
Knowledgeable
Re: What are "collisions"? 7 Critical Errors!
It's on Windows 10 Home Edition Version 1903 on Alienware 15R4 with SyncBackFree V9.2.30.0
markfleener
Knowledgeable
Knowledgeable
ERRORS
8:00:31 PM D:\found.000\ Scan failed (5): Access is denied
8:00:31 PM D:\found.001\ Scan failed (5): Access is denied
8:00:31 PM D:\found.002\ Scan failed (5): Access is denied
8:00:31 PM D:\found.003\ Scan failed (5): Access is denied
8:00:31 PM D:\found.004\ Scan failed (5): Access is denied
8:00:31 PM D:\found.005\ Scan failed (5): Access is denied
8:00:31 PM D:\found.006\ Scan failed (5): Access is denied
I did find the 6 files it had a problem with and it's no big issue, can probably do without them, but what's the problem anyway?
markfleener
Knowledgeable
Knowledgeable
Okay, so I transferred the files it was having a problem with manually and tried running the mirror profile again. It's still coming up with 7 critical errors that I copy/pasted in the above comment.
markfleener
Knowledgeable
Knowledgeable
Apparently, i was wrong about what files it was having a problem with. How do I find out what's causing this problem?
markfleener
Knowledgeable
Knowledgeable
I figured it out. I had to set the view options on Windows 10 to show protected system files. Then I was able to delete all the file Syncback was having problems with. I'm not sure where they came from, but everything seems to be fine now that they're gone.
