Where are the log files?
SteveMann
Post by SteveMann »
I get an error after running Sync Back that says I have one file that can't be opened. Check the log file.
OK, where is the log file?
I tried setting uo my email to receive the log file, but after hours of running SyncBack, this is all I got:
Code: Select all
Copied: 3 Critical Errors: 1
No log file is attached.
How can I find out what is the file that can't be opened?
Re: Where are the log files?
To view the log file, select/highlight the profile from SyncBack main-window > right click > select 'View Log' > Newest from the pop-up menu.
