Specifying Columns for runs
I"m sure this is obvious, but I"m missing it....... I'm running 9.2.xxx on Windows 10. Works fine except I can't specify the columns I want to see during the run. I want to remove "Background", and add "Progress" (I think) - the place where it shows that work is getting done - scanning, file copying and deleting and such.
Re: Specifying Columns for runs
I think want you want can be accomplished by clicking on "View" at the top and then clicking on the down arrow in the box to the right. Then you can uncheck "Background" and check "Progress".
Good grief! I looked all over Syncback and never realized that downarrow was operational. I thought it was just information. This new interface is going to take a little getting used to.
Thanks for the help.
