How do I find out what are the differences between two mirrored drives?
markfleener
Knowledgeable
Knowledgeable
Post by markfleener »
There's two 3 TB (2.72 TB) external USB drives, same kind, one is a mirror of the other, but there is around 3 gigabytes difference between them. The original has 659 GB free, the mirrored one has 656 GB free. I wonder if perhaps it has something to do with, well, how do I explain?... When I rearrange files on the original and mirror the matter to the back-up drive, the SyncBack profile then has RED entries for the old files that can be "cleaned up". There's so much stuff on the drives, I can't actually check every folder to see if there's any RED entries in them to be cleaned up, so is there a way to see all the RED entries in the profile/drive without having to check each individual folder? Maybe that would fix this issue?
