What does: "Failed to scan files: Cannot read from zip file. (505) (Destination)" mean?
This occurs on what appears to be a random basis (every second or third time) on several backup profiles. This also makes SyncBackFree unreliable.
I have several backups scheduled after 11 PM and separated by ~30-minutes.
This appears to be a recent problem since I have been using SyncBackFree fro many years. A manual run seems to work.
Windows 8.1, 64-bit with SSD.
SyncBackFree V9.3.40.0 (32-bit)
Backup is zipped using 7-Zip and saved to an external SSD.
Using for example:
cscript "C:\Program Files (x86)\2BrightSparks\vbs_files\TimeStamp.vbs" "\\RT-AC88U-FILES\Backups - David\Misc\Downloads.zip"
Where "RT-AC88U-FILES" is the external SSD. It is shared between me and my wife via an ASUS router. Her computer is off at night.
Re: Failed to scan files: SyncBackFree is unreliable
Further investigation shows that SyncBackFree is unreliable.
I run certain backups every night (7, well spaced), and others once a month (9, timed so as not to interfere with the nightly runs).
Notes:
1.) Backups are reported (in logs) as "Scan Failure" but the backup files are there.
2.) Backups are reported as "Success" but the file is not there.
3.) Items 1 & 2 are not consistent, i.e. not the same backup on consecutive nights or on any consistent pattern.
4.) The backup can be run manually with no problems.
Conclusion: After many years of use, SyncBackFree is currently unreliable and should be posted as such!
Notes:
