hi, can i choose only desktop.ini-files to be copied from 1 partition to another?
E:\ to I:\  ?
In all folders, all files habe to be checked on E:\ and they should be copied on I:\ to the same places(folders).
Is it possible to copy only desktop.ini-files?
				o0Julia0o
