Hi There:
I wish to run mirror profiles, for each of my major data folders (My Documents, My Pictures, My Videos, etc.).
I have set up mirror profiles in SyncBack Free. I expect that everything in my Source folders will be copied into the Destination, anything changed in Source will be changed in Destination, and anything deleted in Source will be deleted in Destination.
However, when I ran the initial Mirror profiles, I checked afterward and a bunch of folders in (Source) My Documents which have files are empty in the corresponding folders in Destination. I have run this several times. The Destination folders are always empty.
Can someone explain to me why this is? Why aren't the existing Source files being copied over?
Do I need to run these as Backup profiles first, and then change the profiles to Mirror?
Wayne
Mirror profile, folders still empty
Re: Mirror profile, folders still empty
I suggest you look closely at "Choose sub-directories and files" and "Change Filter" as I usually find there are some not checked or a filter is wrong.
waynrayn
Thank you for the suggestion.
smccoy
I am having a similar problem, I think it might be a bug in the program. When I create a new profile, choose mirror, select my documents folder and then run it, less than 1/2 the folders are copied to the new destination.
