Automaticaly selected folder
BAD
Post by BAD »
When I use the copy function on a network drive.
New folders created on this drive are automatically selected in the application.
I only want to use the folders previously checked.
Anyone have an idea? :xmas)
Thank you in advance,
Re: Automaticaly selected folder
If you are synchronizing and don't want the destination folders copied back to the source then make your profile a Backup.
"A backup process copies files in one direction: from the source to the destination. A Synchronization process copies files in both directions: from the source to the destination and from the destination to the source."
