How to make a profile run only manual and not automatic
jackdashack
Post by jackdashack »
I want to have a couple of profiles not run for awhile without deleting them. Is there an option. Or can you do it with some way in scheduleing?
THanks, jack ":-Dx
damiensmith219
Re: How to make a profile run only manual and not automatic
Post by damiensmith219 »
Yes, you can stop a profile from running automatically without deleting it by turning off its schedule. Go to the scheduling settings of the profile and disable or remove any automatic triggers. This way, the profile will only run when you start it manually.
