Problem with FTP Backup
oevesque
Post by oevesque »
I used to use the "smartftp " option with great satisfaction.
But now, it had switch to Weonlydo and it doesn't work anymore.
When using mirror, the program see that all the destination file have 00:00 (which is not true) and as time so they're all different from original. So all files are all deleted and backed up again.
When you have 4 To of data, it's quite long....
The other option Eldos does not back up well file with special code in their names (é, à , ç, etc) and because it's a french folder I've got a lot of this kind of file.
The FTP is on a Nas Synology.
If you have any idea to make it work again
oevesque
Re: Problem with FTP Backup
Post by oevesque »
Here are FTP Parameter:
17/02/2021 14:44:20: SyncBackPro V9.4.14.0 (64-bit)
17/02/2021 14:44:20: Windows 10 x64 build 19041
17/02/2021 14:44:20: Connecting to server
17/02/2021 14:44:20: 220 Nas-Olivier FTP server ready.
17/02/2021 14:44:20: Sending authentication data
17/02/2021 14:44:20: USER backup
17/02/2021 14:44:20: 331 Password required for backup.
17/02/2021 14:44:20: PASS *
17/02/2021 14:44:21: 230 User backup logged in.
17/02/2021 14:44:21: FEAT
17/02/2021 14:44:21: 211- Extensions supported:
AUTH TLS
PBSZ
PROT
CCC
SIZE
MDTM
REST STREAM
MFMT
TVFS
MLST
MLSD
UTF8
211 End.
17/02/2021 14:44:21: OPTS UTF8 ON
17/02/2021 14:44:21: 200 OK, UTF-8 enabled
17/02/2021 14:44:21: PWD
17/02/2021 14:44:21: 257 "/" is current directory.
17/02/2021 14:44:21: Connected to server - idle
17/02/2021 14:44:22: SYST
17/02/2021 14:44:22: Executing command on the server
17/02/2021 14:44:22: Connected to server - idle
17/02/2021 14:44:22: 215 UNIX Type: L8
17/02/2021 14:44:22: Checking if remote directory exists
17/02/2021 14:44:22: CWD /Disque 4 Nas/xxxxxx/
17/02/2021 14:44:22: 250 CWD command successful.
17/02/2021 14:44:22: UNIX Type: L8
17/02/2021 14:44:22: Sending data to server
17/02/2021 14:44:22: Setting transfer mode
17/02/2021 14:44:22: TYPE I
17/02/2021 14:44:22: 200 Type set to I.
17/02/2021 14:44:22: Changing current directory
17/02/2021 14:44:22: Getting secondary data channel
17/02/2021 14:44:22: PASV
17/02/2021 14:44:22: 227 Entering Passive Mode (192,168,1,20,216,244)
17/02/2021 14:44:22: STOR SBSE____.IJQ
17/02/2021 14:44:22: 150 Opening BINARY mode data connection for 'SBSE____.IJQ'.
17/02/2021 14:44:22: 226 Transfer complete.
17/02/2021 14:44:22: MFMT 20210217134422 /Disque 4 Nas/Series/SBSE____.IJQ
17/02/2021 14:44:22: 213 Modify=20210217134422; /Disque 4 Nas/xxxxxx/SBSE____.IJQ
17/02/2021 14:44:22: XCRC "/Disque 4 Nas/xxxxxx/SBSE____.IJQ"
17/02/2021 14:44:22: 500 XCRC "/Disque 4 Nas/xxxxxx/SBSE____.IJQ": command not understood.
17/02/2021 14:44:22: XMD5 "/Disque 4 Nas/xxxxxx/SBSE____.IJQ"
17/02/2021 14:44:22: 500 XMD5 "/Disque 4 Nas/xxxxxx/SBSE____.IJQ": command not understood.
17/02/2021 14:44:22: Renaming file on the server
17/02/2021 14:44:22: RNFR /Disque 4 Nas/xxxxxx/SBSE____.IJQ
17/02/2021 14:44:22: 350 File exists, ready for destination name.
17/02/2021 14:44:22: RNTO /Disque 4 Nas/xxxxxx/SBSE____.TMQ
17/02/2021 14:44:22: 250 RNTO command successful.
17/02/2021 14:44:22: Removing file or directory
17/02/2021 14:44:22: DELE /Disque 4 Nas/xxxxxx/SBSE____.IJQ
17/02/2021 14:44:22: 550 /Disque 4 Nas/xxxxxx/SBSE____.IJQ: No such file or directory.
17/02/2021 14:44:22: DELE /Disque 4 Nas/xxxxxx/SBSE____.TMQ
17/02/2021 14:44:22: 250 DELE command successful.
17/02/2021 14:44:22: Features supported by FTP server:
17/02/2021 14:44:22: MODE Z: Non
17/02/2021 14:44:22: MDTM: Oui
17/02/2021 14:44:22: MFMT: Oui
17/02/2021 14:44:22: MFCT: Non
17/02/2021 14:44:22: MLST: Oui
17/02/2021 14:44:22: SIZE: Oui
17/02/2021 14:44:22: REST: Oui
17/02/2021 14:44:22: XCRC: Non
17/02/2021 14:44:22: XMD5: Non
17/02/2021 14:44:22: SHA1: Non
17/02/2021 14:44:22: SHA256: Non
17/02/2021 14:44:23: UTF8: Oui
17/02/2021 14:44:23: RMDA: Non
17/02/2021 14:44:23: MFF: Non
17/02/2021 14:44:23: AVBL: Non
17/02/2021 14:44:23: Passive connection: Oui
17/02/2021 14:44:23: Can set file last modification date and time: Oui
17/02/2021 14:44:23: Can set file creation date and time: Non
17/02/2021 14:44:23: Supports safe copies: Oui
17/02/2021 14:44:23: Supports resuming: Oui
17/02/2021 14:44:23: Supports file hashing: Non
17/02/2021 14:44:23: Supports Unicode (UTF8): Oui
17/02/2021 14:44:23: Supports faster directory listings: Oui
And to resume:
My files have the same property times on my local folder and on my NAS Synology with FTP.
But Weonlydo FTP see only midnight (with the good date) instead of good date with the real date.
So he overwrite every file because for him, they don't have same properties.
But in the end, the overwritten files have all the good properties time on my NAS !
Netherless, if I run a new session, he will again see midnigth (00:00 )on NAS and he will rewrite all files.
Does the pro version will work ?
