How to copy case-sensitive folder?
cagross
Post by cagross »
Hello. I've created a SyncBack profile to backup a folder which is located on another computer, so the backup is occurring over the network. When I run the profile, SyncBack fails to copy that folder, with the error:
Code: Select all
Scan failed (442): The file cannot be opened because the path has a case-sensitive directory.
The folder is indeed case-sensitive, was intentionally made that way by me, and needs to remain case-sensitive. Is there any way to allow SyncBack to copy this case-sensitive folder? If not, other than making the folder case-insensitive, do I have any other options to backup this folder with SyncBack?
Thanks in advance.
Re: How to copy case-sensitive folder?
You don't say what the OS is on neither the source nor the destination. This is important as we just guess and may be wrong. Please provide if the below guess is wrong.
Syncback ignores the case and can’t work properly in some instances when it might matter.
Windows doesn't care what the case is so perhaps one or both computers might not be Windows. Perhaps the other computer is Linux and has two directories that only differ in the case. Syncback would not know which you want to open so it flags an error.
cagross
Post by cagross »
OK yes, sorry about that--forgot the OS. The OS on both computers is Windows 10. But on the source computer, I actively took steps to change the folder in-question from case insensitive to case sensitive. This is because the folder in-question is a Git repo, which in this case needs the folder to be case sensitive. So I have to leave the folder as case sensitive.
Thoughts? Is there a way to tell Syncback to ignore case sensitivity when copying this folder?
OK, Syncback can not likely solve your problem as it is stated that in itself Syncback is case-insensitive. It cannot differentiate between 2 files or directories that differ only by case.
The link below may provide you with a work around on the Git repo side.
https://dzone.com/articles/git-and-the- ... ensitivity
cagross
Post by cagross »
OK thanks for the info--I appreciate it. In this case, I can live without backing up this folder.
