Profiles scheduling
lion62
Profiles scheduling
Post by lion62 »
In the profile summary there are both last and next execution of the record I saved.
Does anyone know how to prevent a profile from starting before scheduling time?
If I power up my desktop before the next execution, SyncBackFree starts the profile immediately and I do not like that.
Many thanks in advance
Re: Profiles scheduling
The task scheduler does the starting of your profiles not SyncbacFree. The task scheduler is part of the OS and therefore is where you need to look for your problem. If you don't know how to use the task scheduler then I would suggest you search the internet to learn. Also you didn't say which OS you are using but I know Windows has plenty of help on the internet.
Good luck.
lion62
Post by lion62 »
Many thanks for your precious suggestions. I'll do it
