SyncBackFree 10.1.24.0
Windows 11
I've created a manually-triggered group to copy selected directories from my NAS to my laptop. On the first profile in the group, I selected specific subdirectories under the source directory since I don't want to copy everything. It works fine.
I then copied that profile and changed the source to another directory, under which I'll once again select specific subdirectories. However, when I try to select them on the new profile, I still see the ones from the other profile. I can't find any way to view the new source's subdirectories . There's no way to navigate to the new source directory, nor to force the profile to update / re-read.
What am I missing?
Thanks.
Wrong subdirectories shown in copied profile
				lphilpot
				lphilpot
Re: Wrong subdirectories shown in copied profile [Solved]
Never mind, I'm an idiot.
  I figured it out. It's the "remove folders from the tree that do not exist" button. Based on the wording I didn't think that was it, but it apparently is.
Thanks.
						Thanks.
