Notice - Profile requires your attention before continuing
Alex1776
Post by Alex1776 »
I set up my profile for a mirror back up according to the manual directions. It seems to be OK. Every time I run the profile to backup the USB drive it is associated with I get a notice saying that the profile requires my attention. I have no idea what it is telling me to do, fix, or change. Nothing is indicated as a problem - if Syncback even indicates a problem with a profile. Backup runs and is successful when I click continue. What is this trying to tell me - where and how do I find out what is wrong? I am just making an assumption since the back up is successful that it is a correct and complete backup. I had been using an older version of Syncback. I changed computers and just installed SyncBackFree v10 on Win 10. I never had this happen with the old version. Any help appreciated!
Re: Notice - Profile requires your attention before continuing
You can disable profile prompts by going to Global Settings and check the box "Disable profile prompt notifications for ALL profiles: If enabled then profile prompts are never shown. This is a quick way to switch off the notifications if you find them distracting"
Alex1776
Post by Alex1776 »
mmullins_98 wrote: ↑
Sat Nov 12, 2022 11:27 am
It is not so much that the notice is distracting BUT is it telling me there is something wrong? That is my concern - that profile is not set up correctly and it is telling me there is a problem with the profile.
Display a notification when a profile prompts: If enabled (the default), when a profile prompts a Windows Notification will be activated. If you click on the notification then the SyncBackFree window will be brought to the front. A prompt includes displaying the Differences and File Collision windows.
