Updating the SyncBack scheduled task with PowerShell
tgadois
Post by tgadois »
Hello. I noticed that the scheduled backup was no longer working, and that it was from the scheduled task configuration. More specifically, the security setting. So I would like to deploy a patch to fix this.
And to do that, I wanted to know if it was possible to use PowerShell to modify the scheduled task, and change the security setting from "Run weather user is logged or not" to "Run only when user is logged on”.
I've tried several things to set it up, but nothing works so far.
Re: Updating the SyncBack scheduled task with PowerShell
Use the Windows Task Scheduler directly instead of going thru Syncback or PowerShell
On Windows Vista and newer go to the Control Panel, switch to Classic View (option on the left of the window), double-click Administrative Tools, then double-click Task Scheduler. Alternatively, press the Windows key and type Scheduler. Click the Task Scheduler entry that appears.
On the left of the Task Scheduler window you must expand the tree to Task Scheduler(Local) -> Task Scheduler Library -> 2BrightSparks -> SyncBackFree. Under the SyncBackFree node are entries for users. Click on the one that has your login username. Then click on the scheduled item in the right window that you want to modify. Then double click it or right click and select properties. You can make your changes there.
tgadois
Post by tgadois »
Thanks for your feedback, my problem is that I would like to deploy this patch on several hundred machines. And I thought it would be interesting to be able to automate this patch rather than going through the computers one by one.
I realize that I am not asking for the simplest thing.
