double running the task
Libor357
Post by Libor357 »
Hi, I have a problem with using syncbackfree for nightly PC backups. When we turn on the PC through Power on By RTC Alarm and 5 minutes later, a backup starts with the command to turn off the PC after completion. This part of the deposit will be processed correctly. But there was a problem that in the morning when I start the PC, after about 7-10 minutes syncback starts the same task again and turns off my PC. Has anyone encountered this problem after Windows updates since 10/23/2023? I can't figure out what causes the task to start again after about 7 minutes when I log in to the system.
Re: double running the task
Suggest you untick the box "Run task as soon as possible after a scheduled start is missed" in Windows Task Scheduler under Settings for your task.
jamssyyy
Post by jamssyyy »
Libor357 wrote:
Fri Oct 27, 2023 8:23 am
Thank you for bringing up the issue you're facing with SyncBackFree for nightly PC backups. It appears that after Windows updates since 10/23/2023, you've encountered a problem where the backup task restarts after logging into the system, even though it had already completed. To troubleshoot, ensure there are no conflicting backup tasks in SyncBackFree and review recent power settings changes. Additionally, consider checking for any updated versions of SyncBackFree. If the issue persists, reach out to the SyncBackFree support team for assistance.
