Hello everybody,
I have a "simple" question, at least for you, as I cannot find the answer while it is very probbably a simple "option" to select...
When running a profile to save data (in this exemple they are just Microsoft Word files) on another drive, if there is not updated data since my last run (in this case I had 54356 files to compare) I get a screen with 18 lines and the word "skip" in the "Action" field...
As the action proposes by SyncBackFree is to "continue execution" skiping these files, isn'it possible to prevent this screen to appear ?
Thank you,
Guy.
How to prevent the screen proposing to skip unchanged files to appear?
				Guy77
- Enthusiastic
