font sizes
Clasof56
font sizes
Post by Clasof56 »
Hello everyone, is there a way to increase the font size on the data screen. everything else is just fine but the print is so small on anything i want to sync that i can hardly see it. thanks...Clas
MikeTaku
Re: font sizes
Post by MikeTaku »
Clasof56 wrote:
Tue Jul 30, 2024 1:20 pm
If the text on your data screen is too small to read, you can easily adjust it. For Windows 11, go to 'Display Settings' and increase the 'Scale and Layout' to make everything bigger. You can also adjust the font size by going to 'Settings' > 'Accessibility' and using the 'Text Size' slider. For specific apps, you can zoom in with `Ctrl +` to enlarge the text. This should make everything more readable.
