SBT 1.2.7 terrible Bug?
SyncBack Touch is a cross-platform (Windows, macOS, Linux and Android) file server for use with SyncBackPro and SyncBackSE. It is free to use with SyncBackPro/SE V10 or newer. For technical support visit https://support.2brightsparks.com/
tramp20
Post by tramp20 »
I am using it with SB Trial 7.6.8 to backup SDCards of my two smartphones to a NAS.
After starting the backup process all seems to run perfect and fast (perhaps ~800-1000 kB/s).
But after a while the transfer speed slows down to ~20 kB/s and all 4 cores of my CPU in the PC are running at 100%.
My system:
Win 10 Build 14361 with 3.3 GHz CPU and 16 GB RAM
2 Android smartphones with WLAN (1x 2.4 and 1x 5 GHz)
files to copy: 6000-9000
The normal job to copy these files (without SB Touch) does not show this behavior.
Re: SBT 1.2.7 terrible Bug?
Post by Kostas »
I suggest submitting a support ticket for your profile by using the Contact Support in the below link in this article and attach the zip file.
Also include the devices' model and their Android version.
tramp20
Post by tramp20 »
Kostas wrote:Hi,
Done.
