I have SyncBackSE V11 on my PC and backup my laptop files using SyncBack Touch.
Is there any way I can control the backup from the laptop?
TIA
How to control SyncBack Touch from my laptop
Pedroble
stdhamza
Re: How to control SyncBack Touch from my laptop
Configure a profile to connect to SyncBack Touch on your phones, then manage and control backups remotely through the SyncBack interface on your laptop.
Reason: Remove link
Reason: Remove link
anna67
hey
yes you can control, use syncback touch for remote management, which will enable you to initiate and monitor backups from laptop.
