as a counterbalance to the restrictions "# [ ] \ / : * ? " < > |" in naming a profile/group my suggestion is to create a function "show_optional_hint_on_mouse_over". When necessary this function will allow to pop up an optional more precise description what a profile/group does. The control element to edit this precise description could be invoked from the profiles (expert-)context menu.
thanks, keltas
easy way to get rid of "# [ ] \ / : * ? " < > |" restriction
keltas
- Enthusiastic
Re: easy way to get rid of "# [ ] \ / : * ? " < > |" restriction
Hi, for the next release, if there are profile notes, and the profile is configured to show them on import or copy, then they will be displayed in a hint when the name is moused over in the main window.
keltas
- Enthusiastic
Great, I'm looking foreward to download
thanks, keltas
thanks, keltas
Hi, the new version (V7.4) has been released and is available now.
keltas
- Enthusiastic
well IT works
- X1009 2015-10-20.jpg (9.14 KiB) Viewed 15167 times
