OneDrive files copied every time!
Mischmaster
Re: OneDrive files copied every time!
Post by Mischmaster »
I followed your instructions and it looks pretty good now.
Latest backup finished without any issues and unnecessary uploads.
Thanks for the good and fast support!
Michael
Mischmaster
after the first successes, I'm still haveing trouble with the database.
I have to delete the database after a few backups because the sizes of the files distinguish then again.
So you're workaround helps, but does not solve the problem.
Is this a problem with onedrive or with every cloud service (or the encryption)?
Thank,
Michael
Post by Kostas »
Mischmaster wrote:Hi,
Thank,
Michael
Please make sure you are using the latest version of SyncBackPro V8 (at the moment it's SyncBackPro V8.3.6.0), do the workaround one more time, then export the profile and send it to [email protected]. When it fails in the future export the profile again (don't do the workaround) and send to us so we can compare the database to the previous profile.
