Backup to "Box" Requires New "Box Code" Every Day
Homer712
Experienced
Experienced
Re: Backup to "Box" Requires New "Box Code" Every Day
Post by Homer712 »
And based on the screenshot below, I still think this issue has something to do with the Box tokens/date/time. Tomorrow morning I will try running the group manually before the scheduled time, just to rule out anything to do with the scheduler.
Homer712
Experienced
Experienced
Post by Homer712 »
Manual backup done prior to scheduled backup this morning failed. Same failure results were given as if I had let the scheduled backup run. Once the manual backup failed there was no way the scheduled backup would run as I did not "reauthorize" SyncBack Pro access to Box.
Although I am sure that this issue will be identified and fixed, I have gone back to having SyncBack Pro schedule daily backups to Dropbox. Those are and have been working perfectly for weeks, even during V8 beta testing. Additionally, to take advantage of the extra free space available with Box, I have installed Box Sync and will experimenting with having SyncBack Pro backup the files to the Box Sync folder.
Homer712
Experienced
Experienced
Post by Homer712 »
One last possible clue. When I went up on the Box web site to download Box Sync I poked around my account a bit. Here's what I found:
SyncBack Pro states that it is linked to my Box account:
Box shows that SyncBack Pro has in fact had access to my account:
Yet, in the "Integration" tab of the Box account it shows no applications linked to my account:
Homer712
Experienced
Experienced
Post by Homer712 »
Any progress on this issue? Currently (as stated in an above post) I am backing up to Box by using Box Sync, but that I could have done without upgrading from SE to Pro. I'd much prefer backing up directly to Box rather than to a Box Sync folder that takes up space on my hard drive, but until this issue is resolved, that's not possible.
Post by Kostas »
We've released a new beta for V8 which should help with this problem.
https://www.2brightsparks.com/assets/so ... _Setup.exe (32 bit)
https://www.2brightsparks.com/assets/so ... _Setup.exe (64 bit)
Choose the correct installer based on your current SyncBackPro installation and install it over-the-top of your existing installation so it can preserve your current profiles and settings.
Let us know how it works out for you.
Homer712
Experienced
Experienced
Post by Homer712 »
Downloaded. Installed. Test backup directly to Box now set up. We'll give it a couple of days and report back. Thanks.
Homer712
Experienced
Experienced
Post by Homer712 »
Spoke to soon. Did download, but, both Windows and Zemana prevent the installation.
Post by mickyj »
Hi, you'll need to configure your anti-virus software not to quarantine SyncBack, i.e. white list it. When we do official releases (not beta releases) we submit the release to be whitelisted with various anti-virus companies.
Homer712
Experienced
Experienced
Post by Homer712 »
Thank you, I had that thought in mind, but, in the world we live in today, I was not going to white list until I heard back from 2BrightSparks that the links were legit.
Homer712
Experienced
Experienced
Post by Homer712 »
Well . . . so far so good. The test backup to Box that I set up yesterday (and ran) and scheduled for 7:40 AM each day ran successfully this morning. We'll give it another couple of days just to make sure, but it looks as though whatever changes were made to the beta release have fixed the issues I was having with Box.
Homer712
Experienced
Experienced
Post by Homer712 »
Third successful scheduled daily backup to Box has just completed. Think we can now consider this issue resolved. Thank you.
