Copy of PC: File (2) can not be copied:
ON2AD
Post by ON2AD »
Since the Syncbackfree V8.218.0 I become everytime the next errors messages:
\SyncBackFree\SyncBackFree_sel.db-shm
and
\SyncBackFree\SyncBackFree_sel.db-wal
with comment:
Copy of PC: File (2) can not be copied: The system could not find the specified file. The file may have been deleted in the time between scanning and the attempt to copy failed.
So take a look on the location and those files aren't in the folder
Using Windows10 Pro up-to-date
How to fix this
Thanks in advance de Pat.
Re: Copy of PC: File (2) can not be copied:
Post by Kostas »
Have a look at this thread: viewtopic.php?f=16&t=13049
ON2AD
Post by ON2AD »
Many thanks Kostas, problem now solved with this solution.
Thanks de Pat
Gary A
Post by Gary A »
Strange. I followed the instructions and added the 2 file exclusions (*\*.db-shm and *\*.db-wal) but I'm still getting an error for \SyncBackFree Profiles_sel.db-wal
Any other suggestions?
Gary A
Post by Gary A »
Never mind. :oops: When I copy/pasted, I accidentally included the close parentheses.
KWH
Post by KWH »
Same problem here, SyncBackFree V8.5.43.0. I sincerely hope there a fix in the works for this problem introduced in recent SyncBack updates. I understand that this can be filtered, but we use multiple profiles on multiple computers, and also have several clients that have chosen to use SyncBack and are asking us how to fix this. That is a ton of work to fix something that is a new bug in SyncBack. It is basically a hard-coded and intentional problem that is left up to the users to fix. I do hope the 2BrightSparks folks are paying attention and have plans to hard-code the exclusions for files they create and know in advance are going to be deleted, and thus *always* generate errors. Just sayin'.....
I will pass this on to our development department for their consideration.
unbob
Post by unbob »
Now over 5 years later ...
Per the previous question:
any plans to hard-code the exclusions for files they create and know in advance are going to be deleted, and thus *always* generate errors?
I'm running SyncBackPro v10.2.122.0(64-bit) on Win10 and having the same problem.
Any news/updates re this matter? TIA
