Gibberish where text should be
NginUS
Post by NginUS »
I run Windows 10 Home in a VirtualBox VM on a linux host. This one day I decided to turn the CPU execution cap from 100% to 75%. Soon after starting the VM with this setting, it started to display everything on the screen all kinds of jumbled up. It was like those old video game cartridges when there was dust in them or they weren't seated properly & had bad connections. Also at this time, SBP began displaying the gibberish where the network communications status text should be.
Immediately I think about corrupt data being inadvertently written to disk, so I shut down immediately.
I've since reverted that VM from a backup, & started again with the SBP job. The only files I kept from the corrupted VM were the SBP profiles it exports at exit, & a couple scripts.
Today despite having restored to a backup that hadn't been affected by the scrambled video mess, I see again the gibberish on SBP. Not sure how this can be. Maybe the profiles caused it? I have no idea.
I could use a hand here, would rather not have to rebuild the whole OS & apps & all all over again.
Screenshot:
NginUS
Re: Gibberish where text should be
Post by NginUS »
Is it safe to assume based on the lack of reply here that no one's experienced this kind of mess mine's in?
I guess I'll have to reinstall the OS. :-(
Note that your copy of SyncBackPro V6 is outdated. I suggest testing with SyncBackPro V8 version to see if it helps. If you still experience issues, submit a support zip with debug logs of the profile run for further investigation.
You can download and install SyncBackPro V8 from here, and click on ‘Evaluate’ button to use the 30-days trial:
sherro45
Post by sherro45 »
NginUS wrote: ↑
Tue Sep 04, 2018 7:48 pm
I've since reverted that VM from a backup, & started again with the SBP job. The only files I kept from the corrupted VM were the SBP profiles it exports at the exit, & a couple of scripts.
I could use a hand here, would rather not have to rebuild the whole OS & apps & all over again. https://technologywell.com/gta-vice-city-apk/
Screenshot:
This happen will be as well :(
