Upgrade install error - drive or unc share does not exist or is not accessible
lyndeelu
Post by lyndeelu »
I have Syncbackfree (8.5.5.0 - 32 bit) installed on virtual 'F' drive from which it is happily backing up to a couple of other drives.
In attempting to upgrade to 8.5.97.0, after agreeing to the licence terms, I then get a pop up error advising " The drive or UNC share you selected does not exist or is not accessible. Please select another".
I have tried to install from my 'downloads' folder and I have also tried copying the setup file into the folder in which syncback is currently installed and running successfully.
Can anyone provide advice please on how to address this problem.
syncbackfree upgrade error.png (105.39 KiB) Viewed 1067 times
